Box under the text on "Layout grid"
phabio
Post by phabio » Sun May 03, 2020 11:40 am
Hi all, I'me new on this forum, and sorry forr my bad english.
I'me try to create a Horizontal card using "Layout grid" with 2 column.
On the left I've a image, on the right I need to insert formatted text.
On the right column I've set the background (solid with alfa) property, to create a box similar to the left image.
Then I've put into the right box the some "article" bject.
So, if I render on the browser the page, when I resize the window, the image are right resized, but on the right, the background is not "full rendered".. but is visible only under the text..
https://www.sophieblasi.com/temp/wysiwyg1.png
how can I crete a responsible horizontal card like this?
https://www.sophieblasi.com/temp/wysiwyg2.png
thanks
Fabio
Re: Box under the text on "Layout grid"
Post by Pablo » Sun May 03, 2020 12:54 pm
This is not possible with layout grids. Because with standard CSS you cannot create equal heights.
But you can use a Flexgrid to do this.
phabio
Post by phabio » Sun May 03, 2020 2:36 pm
Thank you Pablo.
I've also tryed with flex grid, without god results..
I try another time with different settings.
thanks
Fabio
