How do I change the page design with "Layout Grid"?
VictorKrs
Post by VictorKrs » Wed May 27, 2020 10:04 am
Hello!
Please tell me a beginner! Responsive web design uses "Layout Grid". It is not clear how to change the design (for example, insert a new "Layout Grid" before the existing "Layout Grid"), the blocks are glued to each other and it is impossible to insert a new design element between them (including a new"Layout Grid"). Please tell me what technique/procedure for changing the page design made on the "Layout Grid", so that you can make changes in the already created one? Thank you in advance for the help of experienced specialists!
Re: How do I change the page design with "Layout Grid"?
Post by Pablo » Wed May 27, 2020 11:13 am
You can use the arrange tools (move to front, move to back, etc) to rearrange objects.
Or drag the layout grid to the top of the page.
Or use the Object Manager.
VictorKrs
Post by VictorKrs » Wed May 27, 2020 6:21 pm
Thank you for your reply Pablo! I can't find how to open " Object Manager".
bkjohns
Post by bkjohns » Wed May 27, 2020 7:54 pm
When you add a layout grid, it goes to the bottom of your page by default. To move it to the top, press Control and the minus sign (-). To move up one at a time just use the minus sign, to move down one at a time use the plus (+) sign. To move to the bottom press Control and the plus (+) sign.
Post by Pablo » Wed May 27, 2020 8:26 pm
You can open the Object Manager via the View menu.
VictorKrs
Post by VictorKrs » Sun May 31, 2020 1:08 pm
Thank you for your help "Pablo" and " bkjohns"!
