waveform player !
amir2314
waveform player !
Post by amir2314 » Sun Aug 06, 2017 10:25 am
hello dear pablo I'm amir rezaeyan , music producer from iran! i need the
new generation of html5 audio player for my website that we called this
waveform player
i find this : https://wavesurfer-js.org please read it if you can
but its hard for me to put it on my wb project! and i don't know how can i
use this script on my projects's , can you put it like an extension on new
wb free update ? i really need it form my website
thank you very much <3
and one of my problem is that when i save my blocks and when i want to put
it on my project again crash happened ...
Re: waveform player !
Post by Pablo » Sun Aug 06, 2017 11:04 am
I'm sorry I cannot help you with third party code.
For me this would also take several hours or days to figure out how this works.
But this may be helpful:
http://wysiwygwebbuilder.com/add_html.html
amir2314
Post by amir2314 » Sun Aug 06, 2017 8:48 pm
Hello again dear pablo , thank you very much for your reply ... mmm then how can i have the waveform html5 audio player on my wb software ? :D i think that wb software should have this item for html5 audio player like soundcloud or beatport , spotify or any other website's :idea: it's just my suggest because wb is the best and power tools for music producer's to help them for share music's and work's , I hope you the best _ ( amir rezaeyan 8) )
Post by Pablo » Sun Aug 06, 2017 8:53 pm
You can use the HTML tool to add the code. However I cannot help you to implement it, because for me this would also take a lot of time.
If it works in other editors then it will also work in WWB, you juts need to spend some time to learn how to use this code.
You are the first user who asks for this, so this is not a frequently requested feature.
But you can post suggestions in the 'Suggestions' section of this forum, so other users can let me know if they find it useful too.
