How to Auto-Populate a Form Using a Link
dvmmvd
Post by dvmmvd » Fri Jun 01, 2018 12:45 am
Here is an example that explains better than I can on what I want to do, and why:
https://www.formstack.com/blog/2012/aut ... form-link/
The trouble is, that link seems to explain how to do it using that particular software. Does anyone know how to set this up using Web Builder 14?
I have found some examples sketched, and they use java. I am not a java user; everything I do in java is from aping what I might see elsewhere. If someone has a detailed example I could review, I'd be grateful. Thank you.
