Incomprehensible paragraph.
siways
Post by siways » Tue Jun 26, 2018 8:39 pm
Good evening. Maybe someone already asked the same question, I will not climb on the whole forum in search of an answer to a question, but I'd better ask here. What does this item mean? "• A license for a single user which can be installed on 3 computers. The license may not be shared with other users." - this means that after 3 settings of the program on different computers I have to buy it again? or that it will work on a maximum of 3 computers at a time?
If I change 4 different computers with absolutely different details, can I install the program 4 times and so on indefinitely ???
Re: Incomprehensible paragraph.
Post by Pablo » Tue Jun 26, 2018 8:45 pm
Correct
If you activate the license too many times in a short period of time, then the license may be blocked automatically.
But we can always reset it on your request.
siways
Post by siways » Tue Jun 26, 2018 8:51 pm
But in the end I can use it unlimited number of times on different computers?
Post by BaconFries » Tue Jun 26, 2018 9:10 pm
1 x Licence means you can install on 3 PC's or 3 Laptops or a mix of both. The License is for personal use only, this means you cannot share it or allow others to use it. If one of the PC's or Laptops breaks/Fails and can no longer be used/scrapped, then you will be able to reinstall that licence (1 of 3) on a 'New' PC or Laptop that you own, as before this is for personal use and it cannot be shared or used by others.
siways
Post by siways » Tue Jun 26, 2018 9:22 pm
And if I change 9 computers? will I have to buy it 2 more times? even if all these 9 times I will use without transferring to anyone? Ie there is a binding to the iron ???
Sorry for the misunderstanding, I translate from Russian to English, I can misunderstand You somewhere.
Post by Pablo » Wed Jun 27, 2018 5:48 am
The license can be active on 3 computers max. For 1 user.
If you need to replace one of those computers in the future, then we can reset the license for you.
siways
Post by siways » Wed Jun 27, 2018 7:57 pm
what do you mean when you say "reset the license"?
Post by Pablo » Wed Jun 27, 2018 8:11 pm
If you activate the license too many times within a short period of time, then your license may be blocked.
If that happens we can reset it so you can use it again.
siways
Post by siways » Wed Jun 27, 2018 8:18 pm
If it happens I will not need to buy it, right?
Post by BaconFries » Wed Jun 27, 2018 8:24 pm
No you will not need to buy again!
siways
Post by siways » Wed Jun 27, 2018 8:45 pm
Many thanks that explained, if it is really so the topic can be considered closed.
