responsive rotating banner - how?
longman
Post by longman » Sun Jul 08, 2018 12:19 pm
Hi guys,
I was able to have a rotating banner by using the following code in the HTML:
function banner() { } ; b = new banner() ; n = 0
b[n++]= "<a rel='nofollow' href='www.domain.com'><img src='www.domain.com/image1.jpg'></a>"
b[n++]= "<a rel='nofollow' href='www.domain.com'><img src='www.domain.com/image2.jpg'></a>"
i=Math.floor(Math.random() * n) ;
document.write( b[i] )
</script>
But I need my image to be responsive, to shrink when the browser window gets smaller. I can make a none-rotating standard image responsive by going to Flexbox > Flex shrink > add 1 value. but how do i do it with the images inside the above HTML code?
I selected the HTML, in its Flexbox I added 1 value for Flex shrink, but it was not applied to the images inside the html code.
All I want is to have a rotating banner, inside my flex container/grid.
Is there a way to make it possible?
PS - by rotating i mean display one banner at a time, randomly.
Thanks!
Re: responsive rotating banner - how?
Post by Pablo » Sun Jul 08, 2018 12:38 pm
Why not use the built-in Slide show? it also supports 'random' mode.
longman
Post by longman » Sun Jul 08, 2018 1:52 pm
I tried but the image gets big inside the flexgrid.
Moreover, I want one image randomly to be displayed by each time the page is opened/refreshed.
Post by Pablo » Sun Jul 08, 2018 3:27 pm
I do not think the slideshow can be inside a flex grid. A slideshow is a JavaScript controlled element, so it will override the flexgrid properties.
However, it should work with layout grids or full width on the page itself.
Please see the help.
longman
Post by longman » Mon Jul 09, 2018 4:41 am
Hi Pablo,
Do you mean this Help page? http://www.wysiwygwebbuilder.com/slideshow.html
I see no mention or option for the photos to be displayed randomly (each time the page is visited). I see it has only the option of animation, after seconds the other images will be shown, which is not my aim.
Moreover, I used Layout grid, it worked but the image did not shrink. I went to image flexbox, add value 1 to Flex shrink, i previewed and it did not shrink.
Post by Pablo » Mon Jul 09, 2018 5:45 am
No, I meant the help (F1)
Random
The images will be displayed in random order. If you set the 'Pause time' to 0 (zero) then the SlideShow can be used to display a random image each time you visit the website.
Please set full width to 'true'
longman
Post by longman » Mon Jul 09, 2018 7:06 am
Thanks! worked nicely! Wish it was possible to add Slide Show to Flexgrids too, I have sidebar banners in flexboxes (can't use layout grid for sides) then i could make sidebar banners rotating too.
longman
Post by longman » Mon Jul 09, 2018 8:10 am
once it worked, images was shown randomly by each refresh, now it does not work.
I can't figure out what's wrong?
I have attached example file here https://expirebox.com/download/256ab1cd ... 450e7.html
appreciate your help!
Post by Pablo » Mon Jul 09, 2018 8:57 am
The image file name is invalid.
https://www.wysiwygwebbuilder.com/forum ... f=10&t=131
Also, I think you will need to add more images.
longman
Post by longman » Mon Jul 09, 2018 9:11 am
it was the number of images. it does not work with two photos, but more than two photos.
Is there a reason for it? or a bug? I wanted to have two banners rotating...
Post by Pablo » Mon Jul 09, 2018 11:58 am
I think this is a limitation of the random algorithm of JavaScript.
