google translator
erickfreetie
google translator
Post by erickfreetie » Sat Aug 04, 2018 5:59 am
dear WWB comunity
i have tried to put in my page footer the google translator https://translate.google.com, i paste the google code with HTML but nothing happened
even on this way > page HTML >end of page but doesnt work
somebody help me!! thanks
Re: google translator
Post by BaconFries » Sat Aug 04, 2018 6:27 am
end of page is reference to were the code will be inserted in the HTML source not the position it will be displayed on the page (footer). Use the HTML Object for this adding the code and then place the object on the footer of the page.
To make it easier for you why don't you simply use the 'GoogleTranslate' from Ready-to-use-Javascripts in miscellaneous just drag'n'drop to page set to the language required and place were you want.
Post by Pablo » Sat Aug 04, 2018 6:34 am
Also note that the code will probably only work when the page is online.
