Show element in different felxbox containers
tom248
Post by tom248 » Fri Sep 28, 2018 12:30 pm
I have a Problem wich i can't solve.
I have implement a editbox in to a flexbox container "1"
Now wenn the editbox receive a value via the SQL connector, than this editbox should be displayed in another place -> e.g. in the flexbox Container "2"
How can i do that?
Re: Show element in different felxbox containers
Post by Pablo » Fri Sep 28, 2018 12:54 pm
This require programming/scripting, this cannot be done 'visually'.
tom248
Post by tom248 » Fri Sep 28, 2018 4:18 pm
Ok thanks. and there are also no "work around" possibilities?
Post by Pablo » Fri Sep 28, 2018 5:09 pm
There is no 'workaround. You will need to implement code for this.
