Cookie policy appears again in the same browser session
tommy888
Post by tommy888 » Wed Aug 21, 2019 8:01 pm
Cookie policy doesn't disappear as it should be after it is clicked on an AGREE BUTTON in the same browser session. What might be the caus it used to work? Pablo, can you have a look at the index page of the project? Thank you very much.
I don't have any external extensions or scripts apart from Google analytics, but it doesn't make a difference I checked.
http://tomdesign.esy.es
Re: Cookie policy appears again in the same browser session
Post by Pablo » Wed Aug 21, 2019 8:23 pm
I'm sorry, there is no support on this extension. It is provided "AS IS".
tommy888
Post by tommy888 » Wed Aug 21, 2019 8:31 pm
Any script to close a sticky layer for the browser session?
The one used is Klaus Hartl 2011 -
Post by Pablo » Wed Aug 21, 2019 8:32 pm
There is no standard solution, this will require a custom script.
tommy888
Post by tommy888 » Wed Aug 21, 2019 9:46 pm
Nothing can be done from the latest release of his script
https://github.com/js-cookie/js-cookie/ ... .cookie.js
Billywiz
Post by Billywiz » Thu Aug 22, 2019 5:47 am
I don't know if this is of any use to you but it's the one I use and it's highly configurable
https://www.websitepolicies.com/cookie- ... -generator
Cheers
The Cheapest Car Hire, Worldwide.
Summit Car Hire
tommy888
Post by tommy888 » Thu Aug 22, 2019 9:34 pm
Thank you guys for your assistance. I need a personalised, fully customizable cookie pop-up with built-in script not external ones.
I managed to solve the issue.
alan_sh
Post by alan_sh » Fri Aug 23, 2019 11:41 am
How did you do that?
Alan
tommy888
Post by tommy888 » Fri Aug 23, 2019 12:58 pm
You need to check manually which script causes problem. It's some work, but necessary. The old version of the script still works even in the modern browsers.
