i need help to create website self-managed
MUDJ
Post by MUDJ » Mon Nov 18, 2019 11:50 pm
Hello all!
I've to create a website for a client and the same client have to self upgrade the website. Any of you know any extension to create it, in base at contents, or mode to create to minimum insert txt and image from private area? Example.. i'm a client and i enter in a private page/area with login. Then, i select the image to upload in exact position and text to insert in a field below. Then, click on update button and the site automatically update the page with image and text.
I hope you have template to understand the type of extension or other ways to create it.
Thanks for your time spent on me!!
me.prosenjeet
Re: i need help to create website self-managed
Post by me.prosenjeet » Sun Nov 24, 2019 7:56 am
As said by Pablo, there is no other option but to use a CMS extension or try the news writer extension to achieve your goal. A blog may come in handy but again, its a blog and not what you are asking for.
www.Lucknowwebs.com
MUDJ
Post by MUDJ » Sun Nov 24, 2019 8:34 am
Hi Pablo and Prosenjeet!
Thanks to reply at mt requests.
Is possible to implement complete extension in the next update to create this in automatic mode without programming?
All this for semplify the creation of complex websites. Forever if it's possible..
Thanks!
Post by Pablo » Sun Nov 24, 2019 8:53 am
You do not need to do any programming to use suggested tools.
me.prosenjeet
Post by me.prosenjeet » Sun Nov 24, 2019 9:22 am
Certainly depends upon your expertise with webbuilder. You may contact me if you need any help through:
https://lucknowwebs.com/contact
www.Lucknowwebs.com
