Some help? Readmore with images
Fender
Post by Fender » Thu Jan 02, 2020 3:25 pm
I've found a script for a readmore/less what shows and hide text .
I inserted an image placeholder and now it also show the image.
Look here; https://jsfiddle.net/b1d3gLxc/ second readmore!
I did this in the programme and now it is the wysiwyg way
You can download my file here
https://gofile.io/?c=OXRkK4
The only downside is that the readmore/less link stays above the text.
I couldn't find a solution in the programme to do it the right way.
Is there somebody out there who can give the solution for this?
Or @ Pablo is this not possible?
Re: Some help? Readmore with images
Post by Pablo » Thu Jan 02, 2020 3:39 pm
I cannot help you with third party scripts.
However, if they work somewhere else then they will also work with WWB.
Alternatively, you can check out these templates which also use a 'read more' script.
http://www.wysiwygwebbuilder.com/suppor ... louds.html
http://www.wysiwygwebbuilder.com/suppor ... inter.html
Fender
Post by Fender » Thu Jan 02, 2020 4:07 pm
It only depends on inserting this; div class="view-btn">View More &#9658</div xx I deleted the last > otherwise it shows on the pagexx
after the last id with the class full-text as you can see in the fiddle
but when I insert it after the last id with class full-text in the programme the script doesn't work
I used html use div
Who can solve this?
I already have a wysiwyg way for only text when somebody is interested I can
provide a wbs just ask
bkjohns
Post by bkjohns » Fri Jan 03, 2020 8:29 pm
Have you tried building it in WWB using events? Works great.
