What could be wrong here...
Re: What could be wrong here...
There is no difference between preview and publish. In both cases, the exact same files will be generated.
I did publish the project to a test server and it's the same results.
For me, it is difficult to make any sense of your project because there is too much content. It may take me hours to figure out what you have done. Also, I am missing all the assets (lottie and images).
I suggest to use less nested layout grids and use more logical names (ID) for the objects. So , the layout becomes easier to understand.
me.prosenjeet
Post by me.prosenjeet »
OK Pablo, I have found an easier way to check it.
Open my wbs file in webbuilder, then go to...
...index page properties > Miscellaneous > Type (change to Masterpage)
Now check the index page inside Webbuilder (don't preview)and see how the footer moves up on the content of the index page.
Check my WB Extensions
Check my WB Templates
www.Lucknowwebs.com
This is not related. A master page work different then a master frame!
Your project is too complicated to make any sense of it. There are nested layout grids with fixed heights. For example LayoutGrid15 is set to 75vh. This does not make sense and the browser may get confused from this.
Please verify your settings or simplify the layout.
me.prosenjeet
Thank you Pablo, got this to work.
It was getting caused as the main layer was set to 100vh.
Thanks once again for your time and patience.
www.Lucknowwebs.com
