need Button to link to a PDF document
terryfoster60
Post by terryfoster60 » Thu Jan 31, 2019 11:35 am
I am looking to generate a button which links to a downloadable or viewable pdf document.
It is for a restaurant who want their menu to be downloadable.
Please can anyone advise how to do this.
I can not get the form button to work
Thank you in advance for any feedback
Terry
Re: need Button to link to a PDF document
Post by BaconFries » Thu Jan 31, 2019 11:55 am
See the following:
Link to a file (ZIP, PDF etc)
https://www.wysiwygwebbuilder.com/links.html
Williams
Post by Williams » Thu Jan 31, 2019 11:56 am
Why do you need a form nutton!!
you can easily insert an image of pdf, and link this image with your menu which should be uploaded onto your host.
is that what you're asking for!!
Post by BaconFries » Thu Jan 31, 2019 11:59 am
A nutton is that a 'New' object in Web Design?
terryfoster60
Post by terryfoster60 » Thu Jan 31, 2019 12:23 pm
Thank you... I am not a nutton.
... many things but not a nutton.
I am new to WYSIWYG and some of the features are new to me.
I have programmed Dreamweaver for years but had to change because of responsive and bootstrap sites.
Thank you
Post by BaconFries » Thu Jan 31, 2019 1:00 pm
Terry form buttons are meant to be used on forms only. If you follow the link I gave you will be able to create a link easily for what you have asked.
windsurfer
Post by windsurfer » Wed Nov 25, 2020 7:08 pm
What terry was asking is to make a link that will download a PDF file which is what i am trying to do but there is no explanation at https://www.wysiwygwebbuilder.com/links.html on how to achieve that. Is there any other help for this ?
I used to have a photographic memory but i ran out of film !!!
Post by BaconFries » Wed Nov 25, 2020 8:04 pm
And the url provided explains this if not what is missing? Did you follow the link reading from
Alternatively you can use the method described in the FAQ:
How to create a download for your websites visitors?
onlye
Post by onlye » Thu Nov 26, 2020 5:59 pm
unless I am missing something...
Put a Themable Button on your site. Set the properties for the Button and add the link to the pdf file.
windsurfer
Post by windsurfer » Sun Dec 06, 2020 4:20 pm
If i add a link to the PDF file it opens the file, it won't download it.
Post by Pablo » Sun Dec 06, 2020 4:30 pm
To create a download link, please follow these steps:
Step 1
Add an image or shape
Step 2
Set the URL of the link to the file.
Step 3
Right click the image or shape
Step 4
Select "Custom HTML"
Step 5
Select 'Inside anchor'
Step 6
Type 'download' in the input field.
wwonderfull
Post by wwonderfull » Mon Dec 07, 2020 7:33 am
A simple way
