I'll be undertaking a major redesign of my website soon.
In the header I'll be having a circle with my logo inside that I want to roll in from the LHS. Ideally it will rotate as it rolls in to a defined position.
How do I achieve this please?
Rolling In Effect
- ColinM
Rolling In Effect
Yours truly
Colin M
Western Australia
Colin M
Western Australia
Re: Rolling In Effect
You can use animations or motion effects to implement this.
http://wysiwygwebbuilder.com/animation.html
http://wysiwygwebbuilder.com/motion_effects.html
See also some of the example templates:
https://www.wysiwygwebbuilder.com/suppo ... rofit.html
https://www.wysiwygwebbuilder.com/suppo ... dding.html
https://www.wysiwygwebbuilder.com/suppo ... orate.html
- ColinM
Thanks Pablo - I've looked at so many existing and new features and your templates - appreciate the narrow down.
Yours truly
Colin M
Western Australia
Colin M
Western Australia
- ColinM
Roll a Circle In from Left on Page Load?
Hi Pablo,
I'm planning to revamp my website in the near future.
I want to "roll in" a large circle into the view port from the left and stop approx 1/3 the page width in.
Is that possible and if so tips on how to do that please?
Yours truly
Colin M
Western Australia
Colin M
Western Australia
Re: Roll a Circle In from Left on Page Load?
You can use Motion Effects for this.
- ColinM
Thanks Pablo - so object event wise, that would be an onscrollreveal via an animate (css3) Action and a transform-roll-in or Motion Effects - Animation (Roll-In) Duration (Slow) and Play (when object is visible)?Pablo wrote: Fri Dec 04, 2020 7:14 am You can use Motion Effects for this.
How do I get the object coming in from outside the view port (i.e. in from left of screen moving right) please?
Yours truly
Colin M
Western Australia
Colin M
Western Australia
With "motion effects' you do not need events. Just select the animation and time.
If you want more advanced animations then you can also use CSS animations or scroll transitions.
See also:
https://www.wysiwygwebbuilder.com/forum ... =5&t=90002
See also:
- ColinM
Thanks again Pablo - looks like I've got a fir bit of research - apologies for the double post - I'd forgotten about that one - good pick up by you!Pablo wrote: Fri Dec 04, 2020 7:48 am With "motion effects' you do not need events. Just select the animation and time.
See also:
Yours truly
Colin M
Western Australia
Colin M
Western Australia
- ColinM
