Im trying to make a transition from a page to another one using an effect (like fade).
If Im using the "on click" event with "link" to give it the target page this takes priority on any other event with effect I might add so everything happens suddenly.
What is the way to do it ?
Thank you
Page transition
Re: Page transition
There is an extension for this:
https://www.wysiwygwebbuilder.com/forum ... =1&t=90329
Re: Page transition
Got it , tx !
I place it on every page and the transition kicks in using "Animation(enter) - fade in
However the Animation(leave) - fade out doesnt seem to do anything..am I missing something ?
Re: Page transition
Works fine for me.
Can you provide more info or copy of your project to look at?
Re: Page transition
So it seems so work everywhere except one single page composed by just one single image.
I will live with it. Tx again for your help.
