google translator
erickfreetie
google translator
Post by erickfreetie »
dear WWB comunity
i have tried to put in my page footer the google translator https://translate.google.com, i paste the google code with HTML but nothing happened
even on this way > page HTML >end of page but doesnt work
somebody help me!! thanks
Re: google translator
end of page is reference to were the code will be inserted in the HTML source not the position it will be displayed on the page (footer). Use the HTML Object for this adding the code and then place the object on the footer of the page.
To make it easier for you why don't you simply use the 'GoogleTranslate' from Ready-to-use-Javascripts in miscellaneous just drag'n'drop to page set to the language required and place were you want.
Also note that the code will probably only work when the page is online.
JonathanD
Post by JonathanD »
Hi All
I have used the 'GoogleTranslate' from Ready-to-use-Javascripts and it does not show up
Ive moved it to my Page Header area
Is there more information about this or a guide please
Did you publish your website online?
JonathanD
Post by JonathanD »
Hi Yes I did Pablo
I googled for a bit more information and saw that google translate no longer supported
Is this True?
Here is the source: https://www.tripepismith.com/google-translate/
or am I being silly and doing something so obviously wrong
Thank you
The script in Ready-To-Use-JavaScripts is a standard Google script so if it's no longer supported then it will no longer work.
JonathanD
Post by JonathanD »
It's in your program if I go look.
Can you please confirm if it is still operational if you were to try it?
I have a client who wants that feature on their site
Thank you in advance
At the moment the script will still work for those who already have it implemented in there site(s). But as of early December 2019 Google have stopped support for its use in all "New" sites made after that date.
JonathanD
Post by JonathanD »
Does wysiwyg web builder have another feature similar to this?
Thank you
Sorry, there is no other translate script. However, you can integrate any third party script via the HTML object.
Note that 'Google Translate" is not a WWB script, it's a Google script and it relies on their translate service.
The script was included in 'Ready-to-use-javascripts' to make it easier to add the script to your website.
