Open In Light Box - Settings bug?
tshoda
Post by tshoda »
Hi
I would like to open a page in a Light Box with the following settings:
'transitionIn':'elastic',
'transitionOut':'elastic',
'speedIn':400,
'speedOut':400,
'overlayShow':true,
'overlayColor':'#ccc0da',
'showCloseButton':false,
'width':430,
'height':650,
'centerOnScroll':true
I've tried putting the data above into the 'settings' but when I publish and preview the page, none of the settings have registered. The page opens in light box but without the setting adjustments.
Does anyone know why?
Many thanks for your help
Re: Open In Light Box - Settings bug?
Did you use this settings in combination with fancybox?
tshoda
Post by tshoda »
Hi Pablo
I think I've used the default:
Link > Target Window> Target: open in a Light Box
The default lightbox is MagnificPopup. This can be set in the Page Properties.
The settings you have used are only valid for Fancybox.
tshoda
Post by tshoda »
Thanks Pablo. I've got it to work :D
