font orientation in different breakpoints
johnsmith0251
Post by johnsmith0251 »
Can the font orientation be changed from left to center in a different breakpoint when using a layout grid? I can't get it to work.
Re: font orientation in different breakpoints
Make sure your text object is set to use responsive fonts, then select the text and choose your alignment.
johnsmith0251
It's working in the program's workspace (responsive selected, centered in different brakepoint), but when i preview or publish ... it stays left.
Then there must be another setting that you have that is incorrect. It works correctly for me. Can you share a demo project illustrating your issue?
johnsmith0251
What other settings could overide the individual breakpoint setting?
To be able to help you, I need a DEMO project (.wbs file) so I can see all your settings.
For further details about how to share a project file, please see this FAQ:
@johnsmith0251,
As Pablo and I have stated, the only way we can help is either you need to provide a step by step instructions on how to reproduce the problem or provide us with a sample project file (.wbs file) that just illustrates your issue. Make sure to remove all non-relevant stuff from the page so we can focus on the problem. There are so many options in WB that it makes it difficult to give you an answer. I work with grids 100% of the time and I guarantee they work but I need to see your setup.
