CMS SHOP + 2.2 RELASED!!!
Please post commercial templates here.
adex1
Re: CMS SHOP + 2.2 RELASED!!!
Post by adex1 »
mindentezzel wrote:I hope I post this message in the right place.
My query: is there an e-book (software, picture etc) shop in this version? I seek a normal e-book store solution, where after paying the costumer can download the book or picture or software. Would you please give me a feed back about it? There are two big questions, how many times can the costumer download the book, and how can you give back the money if he/she got the book.
Thanks, T.
Yeah it has everything you want.
Have a look at this:
URL removed
and backend
http://www.cmsplus.bbbweb.be/get_start.php#categorys
Buy Automation Shopping Cart for CMS WEBSHOP + 2.2 Using WB10!
- Use secure gateway to buy using PAYPAL website.
kuasarx
Post by kuasarx »
basstuuk wrote:Hallo,
Heb een email aan k gestuurd maar krijg geen antwoord.
Heb de webshop gekocht maar geen serienummer toegestuurd gekregen.
Misschien dat het zo lukt om antwoord te krijgen.
Met vriendelijke groet Bas :(
Ik heb de serienummer opnieuw gestuurd.
vergeet niet jij moet het gebruiken in combinatie met uw e-mail in de installatie process.
indien jij meer vragen heft, dan kunt jij contact met mij opnemen via info@bbbweb.be
Web Design , CMS Systems & e-commerce for WYSIWYG 9
adex1
Post by adex1 »
Phuzznutz wrote:How much does this cost in US Dollars?
Start cost from 35euros. Check below link
http://www.cmsplus.bbbweb.be/view.php?p ... andard-ade
@adex1 if you are pointing to your site to sell this then I will remove it again as it is not polite to advertise what you are selling in the original members thread. It is not polite to do this and unfair on the orininal seller of the template.
adex1
Post by adex1 »
BaconFries wrote:@adex1 if you are pointing to your site to sell this then I will remove it again as it is not polite to advertise what you are selling in the original members thread. It is not polite to do this and unfair on the orininal seller of the template.
@BF: I am not selling anything on my website. I was pointing to the website I built with the extension.
Is that the reason inject the website and always after my posts for deleting?
kuasarx
Post by kuasarx »
bryaninuk2 wrote:Hi there, just bought the product and I am not happy with the template, is it possible to embed the products form onto my existing website? I would then be able to use the backend, which looks very good, with my website. What code would I need to copy over to my existing site?
When I bought it I did not realise it was so dependant upon the template.
Thanks Bryan
Hi bryaninuk2.
Yes in fact the shop is template dependant, it carries the 35% of the work.
The best option is that you change the template for suit your needs.
Contact me at info@bbbweb.be and I will help you foward.
thanks.
mayur007
Post by mayur007 »
hi i m trying to login in the admin panel
but says
THE COMBINATION OF USERNAME AND PASSWORD IS NOT RECOGNIZED.
PLEASE TRY AGAIN.
adex1
Post by adex1 »
mayur007 wrote:hi i m trying to login in the admin panel
but says
PLEASE TRY AGAIN.
Hi, at the moment you can not login. Sorry for any inconvenience this might have cause you for not having access to the backend.
mayur007
Post by mayur007 »
ok do let me know although i can wait till Wednesday at max
cdasupport
Post by cdasupport »
How is it that the test viewing login & password for front end & back end do not work ?
me.prosenjeet
Post by me.prosenjeet »
Re: cdasupport
Last post by kuasarx was on December 14th 2014. We are not really sure if he is still active on the forum or if he still supports the extension, Also, if the extension works on the latest WB 10X moving to WB11 soon
Check my WB Extensions
Check my WB Templates
www.Lucknowwebs.com
cadtec
Post by cadtec »
Interessting Product!!!
Does it work with WWB 11?
Best regards,
André
Sharid
Post by Sharid »
Hi
RE:http://www.cmsplus.bbbweb.be/listing.php
I'm interested in this product and just need an update on who actually owns this. The site has broken links and has not been updated for about a year now, so don’t even know if the product is still available, or updated.
I have emailed the site direct a couple of times a few months back but got no reply.
I have a few questions for anyone to answer.
1. Has anyone bought this in the last few weeks/months?
2. Will this work on WB version 11 or is this just for WB10?
3. Has anyone had any contact with the owner of this product in the last few weeks and months?
Having read some of the posts. Below and it’s a bit confusing and who owns this
me.prosenjeet replyed to cdasupport on Sun Jan 17, 2016 7:51 am
Re: cdasupport
Is the owner of this product kuasarx ?
or
Is adex1 the owner as he replied on April 20, 2015 11.43am
adex1 is still active on the forum? and has a link to the site as part of his signature, or is he only bringing thr product to our attention?
There has not been an update to cadtec post on tue March 01. I'm not sure what to think, Please help as -
I'm also interested in this product but don't know who to contact. I don't want to risk buying if it is not compatable with V11 and no further updates as I wanted the webshop + Lifetime update version. :oops:
Sharid
Post by Sharid »
I've just realised that this is a post for cms Shop 2.2. and adex1 signature is for cms webshop 2.2 are these different or the same products? sorry as i might have them mixed up. please advise
me.prosenjeet
Looking at the status I get a feel that the product may or may not work with wb10/11. There has been no updates from the author so my suggestion is - dont risk it
Look for other such extension and you will find some shopping cart - free and pro paid ones too.
Best pf luck
www.Lucknowwebs.com
adex1
Post by adex1 »
@Sharid: I am not the owner but friend with the owner. Kuasarx is the owner and he is going through a lot at moment - his 2 legs were amputed etc.
His webshop extension will work with WB10+. I will ring him tomorrow and ask him to get intouch with you guys.
Sharid
Post by Sharid »
adex1
Thanks for the update, and very sorry to here about about your mate, I would not wish that on anyone. I wish him the best.
I don't mean to be rude, I real want the CMS SHOP with the lifetime updates as i'm setting up a digital download website. I only use WB V11 now, could you ask if it will also work on WB v11
Thanks once again
Sergio Morais
Post by Sergio Morais »
@Kuasarx
Feel better soon. Our thoughts and prayers are with you.
To all members of the forum interested in this thread:
With regard to the extension, I too am interested in this. Having read further, it seems the template is part and parcel of the package. I am interested in knowing just how customizable the template is.
BTW: I am using WB11
Regards
Sharid
Post by Sharid »
Does anyone know is the CMS Shop works with WB v11 or is it only for V10?
and also just as important,
Does the CMS Shop allow customers to log into their account or is this just a straight to cart shop?
I can't see anything on the templates that suggest a CUSTOMER login area/Page
Thanks :?
adex1
Post by adex1 »
Sharid wrote:Does anyone know is the CMS Shop works with WB v11 or is it only for V10?
Thanks :?
Hi Guys,
I have contact the owner on Skype and email but he has gone back to me.
The extension should work with v11.
Thanks.
Sharid
Post by Sharid »
Adex1
Thanks for the update, I really want this product. I'm after the WEBSHOP with life time updates, hence somany question. I understand your mate is going through a hard time hence the delayed replys.
As stated in previous post I did send some emails direct but have not herd anything as there was a few questions that I had raised.
One being around "License Key for 100 Sites." does that mean I can build 100 sites for selling or for personal use as it also states can produce webtemplates for sale
Any info will help
adex1
Post by adex1 »
Sharid wrote:Adex1
Any info will help
Yes, you can build 100 sites for selling or for personal use as it also states can produce webtemplates for sale too.
me I have removed your post as it is Hijacking another users thread with your products for sale when the original post is offering the same. If you feel undone to feel free to contact support but it is unfair to hijack a users thread with your services you wouldn't like it for me to post offering services in any of your threadsbwiuld you
mckrahman
Post by mckrahman »
Hi
Is it responsive shopping cart ?
@LTH Post has been moved to Off Topic section as the question is not related to the programme but a paid extension were hopefully another user of it may answer via email later
kevinp
Post by kevinp »
I'm looking at the cart myself as it seems to tick all the boxes. I sell personalised items and need to add a text box to each product allowing the customer to enter their personalised message. The product editor appears to allow insertion of form items, text boxes, combo's, check boxes etc so my question is can this be employed to add the customisation element so that the message will be passed to the cart and notification email as part of the order? I'd appreciate views form any current users who have experience of the cart.
mckrahman
Post by mckrahman »
Hi
is this responsive extension ?
and will this extension support with wwb 12?
Thank you.
mckrahman
Post by mckrahman »
Hi
I tried to view the developer location and contact details from the web but I did not get. So how can I contact you developer in future also ?
I expect your reply.
Thank you
Sharid
Post by Sharid »
You have to contact the developer via this forum,
Also have a read of the post on page 5 the will explain the developers personal situation. See the post I have on Page 5 and you will get an idea of what i mean.
Hope it helps :oops:
by mckrahman » Sun Mar 05, 2017 11:28 am
It is not a extension but a fully working Template.
Already asked by yourself at the date above in March.
mckrahman wrote: Sun Mar 05, 2017 10:28 am Hi
Please note the last time the Template developer logged or
Last active was Wed Apr 05, 2017 7:12 pm. From what I understand he has health issues so he may or may not be able to respond/reply.
mckrahman
Post by mckrahman »
Hi
is this mobile responsive ?
Thank you
@mckrahman you have previously asked this in March and June of this year with no reply forthcoming. It has already been mentioned that the original developer was last active in April and has major health issues so may not be able to reply. Till he is able to answer you and anyone else with a query there is no need to keep asking the same question over and over.
