PHP Directory Listing (FREE) - NEW VERSION/NEW NAME
- alex4orly
Re: PHP Directory Listing (FREE) - NEW VERSION/NEW NAME
Please click on the following URL to see it
I tried with several different browser and the same result, the files are showing in the list but if you click on any file, ....
http://www.nmaa-rc.org.au/dirlist.php
There is a fullstop after "dirlist.php" in the links.
- alex4orly
Yes, I noticed this but I didn't insert it there, have no idea where it comes from
- alex4orly
In the single configuration option there is an input field where I tried the following :
./previousnewsletters - this is the one that comes up with a dot...
/previousnewsletters - this one doesn't show the files in the folder, just a list with a date Jan 1st 1970 for all the files, but no file names
.previousnewsletters - this one doen't show anything
So, where can I go from here
The files are in a subfolder under the root named "previousnewsletters"
What happens if you just insert the folder name without points or slashes?
- alex4orly
Just uploaded it as you suggest, please see
It converts it to this : http://www.nmaa-rc.org.au/dirlist.phppr ... 013_11.pdf
Strange, it seems to me that you are doing something wrong. Make a page called pdfscan.php drop the extension and set the foldername pdflist ,do not include the pdf in the wbs and upload your test page. Via Filezilla upload the folder pdflist with the pdf files inside to the root, in case the test page is in the root.
- alex4orly
I always upload the PDF's using FileZilla,
No idea how to make a page that includes your extension without WWB, how do I do that?
Cheers
Cheers
As I described you in my previous post, please see the demo http://www.alexmas.cloud/scanfolder
It works both on desktop and mobile. If you want to open the Pdf directly on smartphone you may use Prestigio ebook reader.
- alex4orly
Alex,
I visited your demo and as expected of course it works fine.
In the previous extension I used with WWB (PHP Directory Listing) which as you probably know is no longer supported, the scrip was placed in the root directory of the website, and the Folder where the PDF files were had to be specified in the extension as "./pdffolder" to indicate that the files are in a directory under the root folder.
With your script, it seems that the script and the PDF files are expected to be in the same sub-directory? or am I wrong.
I tried that too but all that I see is the top and bottom bar of the script without the files listed
I used initially your sample project, then I uploaded the script php file maually... nothing helped - I click on a file and it does NOT open the pdf.
So I will try again :
1) I load the script file called dirlist.php into the root of my website
2) I have the pdf files in a subfolder called "previousnewsletters"
WHat should I configure the scrip to point to? I do it all manually, forget WWB for a moment...
Cheers
Cheers
- alex4orly
I will tell you one more thing, in your example, when I view source of the page there is an item that looks like this
<a href="?dir=folderscan/">
folderscan </a>
On my page, this item does NOT exist... Why?
folderscan </a>
FWIW:
Out of curiosity I replicated your structure in a test folder called dirlist.php under the root and then created the previousnewsletters folder under dirlist.php containing 3 pdf files.
"root"/dirlist.php/previousnewsletters/2013_11.pdf
"root"/dirlist.php/previousnewsletters/2014_01.pdf
"root"/dirlist.php/previousnewsletters/2015_11.pdf
Added the extension to the page (no layers or anything).
Published All to dirlist.php and it worked fine i.e. the pdfs displayed when clicking in the list.
So can you see anything different from yours?
http://wwb.batcave.net/dirlist.php
- alex4orly
I must be doing something wrong here, your example works perfectly.
I have the following
root
In there I have all my set files
I also have a file (NOT A FOLDER) called dirlist.php (I renamed what you had in your project as index.php to dirlist.php) becasue my real index.php is something else...
In the configuration of my dirlist.php script, i nominated '.' as the folder location of the script
Now - how do I tell the script WHER / In which folder are my PDF newsletters? there is no configuration for this in the scrip?
1) When you say, "Published ALL, what do you mean? There is only ONE source file dirlist.php
2) In your sample project - there is a FOLDER called "Files" what is this?
root
I mean "Publish all files" in wwb Publish Web Site dialog box.
I don't see this anywhere!!
This is my project file, it'll be interesting if you can see any difference to yours.
http://wwb.batcave.net/dirlist.php/PHP% ... 20Scan.wbs
- alex4orly
Downloaded your project file, yes - it doesn't have a folder named "Files" in it...
Renamed index.php to dirlist.php - didn't change anything
Uploaded the file disrlist.php and dirlist.css (created by the project) into the folder "previousnewsletters"
Have a look what I get : http://www.nmaa-rc.org.au/previousnewsl ... irlist.php
All the PDF files are in that same folder, but none shows in the list
I don't understand why you have now created previousnewsletters in the root.
Just as a test, create a folder in the root called test1 (or anything else).
Use my project asis and publish all files to test1 using the built-in wwb publish.
Create a folder in test1 called previousnewsletters.
Copy some pdf files to previousnewsletters.
See if that works.
I guess the problem may be where you put the html and folders and what they are called.
See if that works.
- alex4orly
I don't have a html
I have dirlist.php which is renamed from your index.php
I meant html genericly.
If you have time just try my project and if that works for you then it must be the placement/naming of your html/files/folders.
I realise the time difference between us!
EDIT:
I reckon the problem is with the file dirlist.php; rename it to anything else.
Or, I would rename the folder to dirlist instead of dirlist.php.
EDIT:
- alex4orly
Hello again,
It finnaly got to me what the problem is - the file MUST be called index.php, this is the only way way you can point to a folder and it will start that page by default, I realized it from your examples - in those examples there is a url that has in it only the folder, without pointing to a filename.php.
So here it is : http://www.nmaa-rc.org.au/news/
And becasue I can't have 2 files with that name in the root / home folder, it MUST be placed into its own folder and within that folder make a subfolder where the files are stored, and specify that subfolder name in the top configuration option of index.php
Questions :
1) How do I change the default sorting to be decending?
2) How to make the columns width to be fixed, not stretch to the full width of the screen?
Cheers
Questions :
Cheers
Excellent, glad you got it working.
Alas, I can't answer your 2 questions.
On second thoughts!
1. To get the order descending
change:
private $__sortOrder = 'asc';
to:
private $__sortOrder = 'desc';
in the php file about line 126.
But beware it will have to be changed after each Publish.
2. Have you tried using a layer, as specified in Help (except I used centre instead of stretch)?
change:
to:
- alex4orly
Thanks, I will try that
Cheers
Cheers
- alex4orly
WWBman,
I tried, but how do I center it?
In the css or the php file? where
I di center in WWB... obviously not enough
In the Help:
2.Certain size and position if you drag and drop the extension on a layer and set the properties to
relative size and position and to stretch the content.
Although I used Alignment Center instead of Stretch Content (DEPRICATED).
No need to manually change anything.
- alex4orly
Can you please send me the script?
I don't manage to get to this setup
There is no script. The options are in the standard Layer Properties.alex4orly wrote: Thu Aug 24, 2017 4:17 am Can you please send me the script?
- alex4orly
Got it, thanks for your help
Cheers
Cheers
