@wwonderfull
Many thanks for the alternative, how'd you get it to work? The bootstrap table extension came with my WWB17 purchase but when I try to link the CSV online table it doesn't appear when previewing it in my browser..
bootstrap screenshots:
url index link:
resulting project:
Search Boxes (InstantSearch.js)
Re: Search Boxes (InstantSearch.js)
@jwhite37 Please note that it is not permitted to share paid extensions in projects they are for personal use only. For the time being I have removed the links so you can confirm they do not use paid extensions.
@BaconFries
sorry, my mistake entirely..
Well I am a paid user so I have the extension. But if you have bought it then you can work with it personally.
Can you show your settings screenshot?
If you want it exactly the way I gave you the screen shot then you need alot if things to do also. Like setting the csv file. And the headers and collum settings.
Here is screenshot of the settings you need to do for the solution:
The csv file from microsoft excel
This is the settings for the extensions.
@wwonderfull whether you have it is not the reason. I deleted the links because if the project included the extensions then others could download the file(project) and then have a paid extension for free. I think it is best if you are offering help you do it privately with jwhite37 by email for sharing projects that may or may not include any extensions such as paid.
Well @bacon No problem as you said. I do understand the paid extension fact. So I told him the same
@wwonderfull
I was under the impression as a paid member for WWB17 that many of the paid extensions came with the purchase (maybe bootstrap table isn't included in this group as it says 'demo' in my toolkit and therefore won't save)...I believe I copied your exact settings but to no avail (the only difference being my file exists as a librecalc doc)
CSV file image:
Bootstrap settings image:
Project image/problem:
Feel free to contact me at jwhite72792@gmail.com if more convenient for the platform/yourself. I have another project I could use your guidance on if interested/available and will pay whatever your time is worth..
CSV file image:
In that case check your email.jwhite37 wrote: ↑Mon Jun 20, 2022 10:54 pm
CSV file image:
