Events - move
SergeFog
Re: Events - move
Post by SergeFog »
With press a button I need to move a "text" to an other position in the page.
SergeFog
Re: Events - move
Post by SergeFog »
I need a possibility that when I press a button, a text or an image changes position in the page.
lummis
Re: Events - move
Post by lummis »
Depending on what you are trying to achieve you could clone the page that has the button and when the button is clicked link it to the new cloned page. On that page change the position of the text that you want moved and remove the button. That will give the appearance of the text being moved.
Re: Events - move
You can use the 'move' action to move an element (when it has an absolute position). This works, also in your project.
I just do not understand why? I do not see the logic?
Also Note that in modern (responsive) layouts, using absolute coordinates is usually not the best solution.
