Glass Effects not function for iphone
alexoliveira
Re: Glass Effects not function for iphone
Post by alexoliveira »
it didn't work on iphone devices unfortunately.
S.A
alexoliveira
I also have the problem of wysiwyg being slow in the latest updates, I have an acer nitro i5 GTX1050 and it still crashes when uploading files or moving the site within the platform, is there any way to improve this?
S.A
'Blur' is standard HTML functionality, so if it does not work then it may be an issue with your browser. Or there may still be invalid scripts on your page.
Here's a working demo that also works for me on my iPhone:
https://wysiwygwebbuilder.com/support/w ... ymenu.html
The software should never crash. There are no known issues otherwise they would have already been fixed.
If you think there is a problem then please share DEMO project and describe the exact steps to reproduce this behavior.
alexoliveira
Could you make me download this wysiwyg file?
S.A
alexoliveira
thanks
S.A
alexoliveira
Could someone be so kind as to provide a menu in this style to download? https://kingthemes.net/
S.A
Do you mean the panel menu?
alexoliveira
Yes
S.A
I believe you can easily create this within WB.
Basic steps:
1. Insert a layer, set type=panel layer and whatever other settings you want
2. Insert a text block for the links (this is what the demo looks like to me-nothing more than text with links)
3. Insert a button/icon/images/etc to use as your menu button and add a onclick-event to toggle the layer1 open/close
4. Add the following css code to a html box between the <head> tags to make it scroll vertically:
<style>
#Layer1_panel{overflow-y:auto;}
</style>
Change 'Layer1' above to match the ID of your panel layer.
alexoliveira
I'm renewing myself to my desktop
S.A
alexoliveira
I'm referring to desktop mode
S.A
alexoliveira
with a panel I can put a blurry effect
S.A
Sorry, you asked for a menu like the desktop. Unless I'm looking at the wrong thing, the desktop menu does not have a blurry background in the link you provided.
However, it is very easy to make the background of the dropdown to be blurry with a little CSS. Just need to know which menu is being used.
alexoliveira
The hover style to indicate the current page in the menu doesn't work, please can someone help me?
S.A
What menu are you using? please be more specific! just saying it doesn't work isn't helpful!.
Note "Hover" does not work in "Mobile" devices as it requires the likes of a mouse to trigger the "Hover" effect when the cursor is over the text/object.
alexoliveira
I'm referring to desktop mode I'm referring to desktop mode https://startagencia.net.br/
S.A
