Grid size in diffrent breakpoints
janez72
Post by janez72 »
I resized grid columns in different breakpoints.
I tried about every setup, but the same thing always happens.
I can change the size of columns and it's also good in preview.
And, it's also good when you publish it, if you are quick enough.
After some time (really can't tell when exactly, because it varies, but it's quickly), the columns would change back to it's values in default view.
Tried all settings with overflow and grid system.
Position is header. Layout fluid, column height auto.
Re: Grid size in diffrent breakpoints
Maybe you have set 'overflow' to 'none'?
In that case, the column definition will be the same for all breakpoints,.
See also the information in the help.
Or else, please share a demo project so I can see all your settings.
Related FAQ:
