WYSIWYG Web Builder 16.0.2 update
WYSIWYG Web Builder 16.0.2 fixes reported problems and includes other improvements.
What's new in 16.0.2?
- Fixed: Missing phone/sms links.
- Fixed: Issue with Layer's Float mode in breakpoints.
- Fixed: Issue with menu title alignment in Responsive Menu
- Fixed: Ramp 3d Divider does not use the selected color.
- Fixed: Wrong play type in Motion Effects.
- Fixed: Issue with flipswitch and 'empty value' workaround.
- Fixed: Compatibility issue with Unicode text and styles when upgrading from WB15.
- Improved: Card image filename now supports PHP code.
- Improved: Background image urls are now quoted.
- Improved: Auto Save no longer kills focus while in text edit mode.
- Improved: Full width text with max-width now has extra div wrapper for use with flexbox layout grids.
- New feature: The application and setup have now been code signed with a digital signature.
Code Signing certificates are used to digitally sign applications and software programs to verify the source of the file along with code integrity:
- You should no longer receive any safety warnings
- You know that the software is real and where the program comes from
- The time stamp ensures the validity of the signature
and hopefully virus scanners will now have more trust in the software as well...
How to update from previous 16.x versions?
2. If you already have version 16.x you can install it in the same location as the previous version.
32bit: https://www.wysiwygwebbuilder.com/wb16update.zip
64bit: https://www.wysiwygwebbuilder.com/wb16x64update.zip
