Hi Guys
Why I can't add font family Code Light.
any ideas why is it not added in the font section?
Can't add font.
Re: Can't add font.
Where did you add the font?
Did you install it in Windows?
Did you uncheck 'Display websafe fonts only'?
em0ng01
Re: Can't add font.
Yes I did installed it in the windows, it usually shown the font in wyswiyg after I installed it in the windows. I did it uncheck and check but its not show the font.
Re: Can't add font.
Maybe it is not a TTF font?
- zinc
Re: Can't add font.
Can you see the font in any other application such as Word if you have it installed?em0ng01 wrote: Thu Mar 11, 2021 5:39 am Yes I did installed it in the windows, it usually shown the font in wyswiyg after I installed it in the windows. I did it uncheck and check but its not show the font.
Proudly running WYSIWYG Web Builder since 2007...
https://50yearsofads.com/
em0ng01
Re: Can't add font.
After I close the application and configure the font setting and it show the font in the selection, and i would like also to ask you about how the selected font working in mobile device, after I uploaded the site it seems in mobile version not shows the font that I choose, only in PC.
Re: Can't add font.
See the following:
https://www.wysiwygwebbuilder.com/webfonts.html
