I've been trying for three days to put a database together with WB, but I am still lost. There is LOTS of literature about it in WB Help, YouTube, and elsewhere, and all the individual descriptions and instructions both make sense and work. But when I try to put it all together, the pieces won't fit with each other! They are like pieces from several different jigsaw puzzles that refuse to build one complete picture.
NEED ONE: Does WB have a built-in database admin panel I can substitue for phpMyAdmin? If so, I have not found it.
PROBLEM TWO: My website host, Freewha.com, provides a panel named phpMyAdmin, and I've spent some hours learning to use it. But it is in a subfolder I can't see, along with the database it creates, and I haven't been able to find a way to link WB to this hidden folder/database. So I created a new folder I can see, and used WB to create a database in it. But the site's version of phpMyAdmin can't seem to find my new database.
PROBLEM THREE: Into this new folder, I also uploaded the latest version of phpMyAdmin, right beside my new database from WB. Then I tried to run this new copy of phpMyAdmin from its "index.php", but only got an error message about missing files, which also stated I likely didn't set the software up first. So I entered its subfolder named "setup", and clicked the file inside which is also named index.php". That gave me only a while screen, where nothing more happened.
PROBLEM FOUR: The error message from attempting to run phpMyAdmin also told me I seemed to be missing supporting software, starting with "Composer" which would find and install additional software as needed. aaaAAAHHH!!! I stopped there, due to wanting something simple I can set up for others with the simplicity they need to maintain things themselves. I don't want to install more and more software that requires more and more software to run more and more software; that could go on to infinity!
NEED FIVE: Does WB have an interface for the database I created, for auto-entering data from customers into my relational MySQL database with "product", "customer", and "sales" tables? Likewise, does WD a way to read monthly data collections in a spreadsheet? I have not yet found found those features.
Sincerely,
Struggling and Lost
Lost in a database desert. Each Oasis is only a mirage.
TIP:
TIP:
- CosmickGold
Re: Lost in a database desert. Each Oasis is only a mirage.
No, if you want to work with database then you will have to get familiar with phpMyAdmin.NEED ONE: Does WB have a built-in database admin panel I can substitue for phpMyAdmin? If so, I have not found it.
Databases are not stored in folders. if you create a database with phpMyAdmin then it is accessible from any folder on your website.But it is in a subfolder I can't see, along with the database it creates, and I haven't been able to find a way to link WB to this hidden folder/database.
Step 1:
Create the table in phpoMyAdmin
Step 2
Enter the username, password, databasename and table name in the properties of the login tools.
You should not have to install phpMyAdmin yourself, this is should be done by your web host.PROBLEM THREE: Into this new folder, I also uploaded the latest version of phpMyAdmin, right beside my new database from WB.
I cannot help you with installing this third party software on the web server. But I don't think phpMyAdmin should be installed in the same folder as your pages.
You can edit basic tables with MYSQL CRUD, but you still need phpMyAdmin to setup the database.Does WB have an interface for the database I created, for auto-entering data from customers into my relational MySQL database with "product", "customer", and "sales" tables?
- CosmickGold
Wow Pablo,
I was very impressed to be receiving a reply from you, the man at the top, who did it all. Thank you for taking the time.
I am still being unable to log in. The closest I get is with this setting:
http://www.webviews.us/images/login.png
Which returns the following pair of errors:
I'm making my login attempts from:
http://www.webviews.us/login.php
I Googled "mysqli", and read that it's the newer version of MySQL, with more advanced features. But I don't see a way to ask for it in the log-in form.Warning: mysqli_connect(): (HY000/1045): Access denied for user 'www.webviews.us'@'localhost' (using password: YES) in /home/vhosts/www.webviews.us/login.php on line 18
Warning: mysqli_error() expects parameter 1 to be mysqli, boolean given in /home/vhosts/www.webviews.us/login.php on line 21
Failed to connect to database server!
My contact info: WebViews.us@gmail.com
The error indicates that the login settings are invalid.
Are you sure these settings are correct?
MGD4me
As Pablo pointed out, likely your credentials are invalid (can't connect), or the database has not been granted user permissions to do so.Failed to connect to database server
The best solution is to get more familiar with some of the basic features of using phpMyAdmin to make sure that the expected database and table exist. Then review the rights granted to whichever user you have selected. The application 'connects' by knowing the correct host, database, table, user, and password.
