Icon fonts shown as squares?
laros
Post by laros »
Hello,
When i want to add an icon font in panel menu, all icon fonts are shown as squares. Any idea why?
Thank you!
Re: Icon fonts shown as squares?
To be able to help you, need more details.
What exactly did you do?
Which icon library did you use?
What is the context of the menu?
Related FAQ:
viewtopic.php?f=10&t=82134
laros
Post by laros »
i have clicked on insert->navigation->panel menu. And when i enter Panel menu i click on Options and than i choose Image and browse. And than there are 2 option: image or icon fonts. I want to choose an icon font that will represent a menu in mobile version.
It works correct for me.
If you need further assistance then please create a demo project so I can see all your settings.
Where are you selecting the icon from? is it from the icons available or are you using one of your own? When you are viewing in the browser and it is showing as a square it could mean that you have not published all files. Please ensure that you have published all files to the correct location and folders used.
