Preloader
alexoliveira
Preloader
Post by alexoliveira »
Could you send me a tutorial on how to add the preloader?
S.A
alexoliveira
Re: Preloader
I have several preloaders in the folder mentioned in the tutorial and they don't appear in wysiwyg
S.A
Re: Preloader
Maybe this will be helpful?
viewtopic.php?t=76719
alexoliveira
Re: Preloader
I didn't move the wysiwyg folder.
C:\Users\documents\WYSIWYG Web Builder\system\preloaders
even with the gifs in this folder they do not appear in wysiwyg
S.A
Re: Preloader
Then maybe the folder is blocked by virusscanner or anti-ransomware?
Are you sure this system folder is set to this folder?
alexoliveira
Re: Preloader
ok, it was right. Can I find a website that provides preloaders?
S.A
Re: Preloader
:roll: hmmm "Google"
alexoliveira
Re: Preloader
what I noticed, is that the site loads before the preloader. how to avoid this?
S.A
Re: Preloader
If you need help then please provide a DEMO project.
Also, describe the exact steps to reproduce the issue.
