Bookmark
Joan Ferrer
Bookmark
Post by Joan Ferrer »
Hello
In some points of my project I have links that go from one part to another of the same project, or other projects (Bookmark)
I have detected that some bookmarks do not work well with firefox, the link I indicate works correctly with chrome and poorly with firefox:
https://www.fotografiamanresa.es/sessio ... html#Nadal
I have tried it on different computers and on a smartphone, and the problem is the same, chrome works and firefox does not work.
I have deleted temporary and history.
Could it be due?
Thanks.
Re: Bookmark
For me, it works the same in all browsers.
What is the exact problem?
What did you expect to happen?
Joan Ferrer
Re: Bookmark
Hello, now I see that it works correctly, I see that it fails sometimes, the indicated link does not go to the place it should go, it is placed at the end of the page, but now I see that it works.
Tnk's
Re: Bookmark
This is standard HTML functionality so it should always work.
Joan Ferrer
Re: Bookmark
ok, tnk's
