Quicksand Portfolio [FREE] for WWB8+
Adendum
Re: Quicksand Portfolio [FREE] for WWB8+
Post by Adendum »
Received - will look at shortly.
Death to Internet Explorer!
Adendum
Post by Adendum »
Simply change your page properties to use jQuery 1.7.2 on the page Games_0.html.
Page tab, Page Properties, Miscellaneous Tab, Advanced, jQuery version - set to 1.7.2
davidpratthk
Post by davidpratthk »
I am still waiting for your reply to solve my problem.
Adendum
Post by Adendum »
Look above your post.....I replied.
davidpratthk
Hi
Didn't notice it was on the second page.
Did what you advised and works nicely thank you.
davidpratthk
Quicksand problems in preview
Strange problem with preview of Quicksand
The correct settings appear when it previews the page by itself HOWEVER ---------- use the whole site option and it just reverts to the default settings.
Is it the addon or the main program?
while I'm here --- if you are not using the text as a link , how can you resolve to eliminate the underline. It shows without in the documentation but I can never get that look in reality.
Adendum
Post by Adendum »
Davidpratthk,
OK, I've now been able to [a] preview a Quicksand page, publish a Quicksand page locally, [c] publish a whole project locally and [d] publish to the server and I cannot replicate your issue. I am using WWB9.04. So it isn't the extension or WWB.
As for the underline - again I can't replicate that.
Sorry!
davidpratthk
OK, I will put it on the back burner whilst we get all our content up on the server and judge it then.
Adendum
Post by Adendum »
Davidpratthk,
OK, let me know by posting in THIS THREAD if you have any further issues. If necessary we can connect via Teamviewer and I can inspect you page/project from here...done that a lot recently!!
davidpratthk
OK, so now we are on the server and problems persist.
The one that I need to address is ( what seems to be ) the inability for changes to occur in the layout properties even though they are applied and I can see the change in one of the previews.
This does not translate to a server update, no matter what I seem to do.
So Quicksand 1.0.0.1, WB9.1.3 JQuery 1.7.2 HTML4.01
I have tried updating , publish changed files only, HTML Only and a full publish. I have tried just to change the page through filezilla. Nada nothing. I have emptied the chache, rebooted the computer and even looked at the site from another computer , nada nothing.
Very strange
Preview page only is what it SHOULD look like and mirrors the page properties
However if you Preview whole site the result is completely different
You can see in the server http://tutorempire.com/All_In_ONE.html that the result is not as properties and is as it was originally designer in the build up stage 1.
Over to you.
davidpratthk
Subsequent actions by doing a FULL install with the WB publish resulted in no change.
Have done a FULL install ( overwrite ) using Filezilla and the previous incarnation has gone and now shows as Preview Whole Site.
neither should be the case because properties are still as Preview One Page.
Adendum
Post by Adendum »
The easiest way for me to resolve this is to see your project file. Email me via my site and I will email you back so you have my address.
davidpratthk
Your info address has kicked me out. please supply a valid address.
The form on your site does not support attachments ( or the support site form )
Adendum
Post by Adendum »
davidpratthk wrote:Your info address has kicked me out. please supply a valid address.
Just use one of the contact forms on either site and send an email. Once I have that I will email you back and you will then have my email address and can reply with a zip file attached.
Adendum
Post by Adendum »
EXTRACTED FROM AN EMAIL TO DAVID - THIS CONTAINED SEVERAL IMAGES
David,
I am not entirely sure that I understand exactly what your problem is. I’ve re-read your forum posts several times now and it is still not clear.....I think you are saying the following:-
In preview mode you see the navigation elements correctly styled? But when you publish you are seeing something different.
And that alone is confusing as in the extension you have SOMEHOW managed to set the Filter Box Content Font (section 3) and Content Font (Section 5) to “Articulate Light” which is not in the list of fonts that are allowed to be used in the extension – how did you manage that? Have you hacked into the extension?
I have edited your page and all works as expected WHEN USING VALID FONTS... I resized and set some different values but you can see it all does what it should (screen grab in email)
And I added this code to the page to remove the underline on the links (for this page only).
<style type="text/css">
a {text-decoration:none !important;}
</style>
I can’t edit and save the page for you as I am using the latest version of WWB. So you need to make the same edits I have. After editing and previewing you should publish the SELECTED PAGE ONLY to your server. As well as the html page it is important that the quicksand.css file is uploaded and the jquery.quicksand.js file as BOTH of these contain the edited settings that control the look and functionality of the extension.
So in summary – as far as I can tell your problems are related to specifying a font that is not allowed and probably not uploading the css and/or the js files needed.
Try again.
mandrake
Help please: Quicksand Portfolio [FREE] for WWB8+
Post by mandrake »
Hi, I can not make "quicksand" extension function. I do not understand what's wrong ... I've done what it says in the pdf. Everything is displayed, but when I click on a category, nothing happens. No movement, no loss of product that does not match the selected category ... I'm in WWB9
Is there a downloadable example, to test and to try to understand where this wrong?
Thank you for your help. Happy New Year 2014!
Adendum
Post by Adendum »
Make sure your page properties are set to use jQuery 1.7.2.
This was built before WWB9 came along, which defaults to 1.9.1
mandrake
Post by mandrake »
Thank you very much, that work fine ! :D
naftalina
Post by naftalina »
naftalina
Post by naftalina »
I just tried extensions and I see the same behavior as on the demo page.
So, the animation works when I switching from ALL to CLASS and from CLASS to ALL. When I switching from CLASS to CLASS animation doesn't work.
