Publishing INFO debug file
http://www.wysiwygwebbuilder.com/publish.html
http://www.wysiwygwebbuilder.com/preview.html
Frequently Asked Questions about Publishing
Re: Publishing INFO debug file
The only way I can help you with this, if if you tell me all your exact settings so I can try it myself.
- tommy888
I'll get back to you Pablo with this issue shortly. First, I will try to fix it myself finding a problem with Firewall. Thank you
- tommy888
WB 15.1.0 - solves my problem with uploading files via built-in ftp client. Thank you, Pablo.
tommy888 your publishing issue might have been the same as mine take a look at https://www.wysiwygwebbuilder.com/forum ... 20&t=86378 and let me know Pablo fixed it in the most recent update released on 20th September 2019 apparently the server i was publishing has some strict rules and Pablo fixed it so it would work Pablo and the team are the best and i would like to thank them for all their hard work and support to the customers.
- tommy888
Yes, that was the issue.
