Strange RWD problem
Re: Strange RWD problem
It looks OK for me;)
alex4orly
Post by alex4orly »
Thanks so much, now i can get on and construct the site
Cheers
alex4orly
Post by alex4orly »
Hello again,
It seems, I was happy too soon. After playing with the break points, it fixed the Ipad but got the Galaxy wrong again
I have only 2 break points - 480, 768 and it seems that at 480 it loads what belongs in 768.
I numbered the captions from 1 to 3, 1 is the full screen on my Windows desktop
Please see some screen shots
This is the initial visit to the page : https://squadron-125.org.il/home2768.php in desktop mode
Here is the image on my phone : Image
Once I close the "x" it comes to this : Image
Then I move the dialog to the right : Image
The page heading says 3 - 480px, but the dialog loaded says 2 - 768 px
Why?
Here is a single page project that demonstrates the same problem : https://squadron-125.org.il/singlepage.wbs
Or visit : https://squadron-125.org.il/page1.html to see it on a mobile phone
Maybe the Galaxy browser is displaying an older version of the page from cache?
alex4orly
Post by alex4orly »
OK, this was of course my first thought... Didn't help.
So, I tried on my mobile 2 other browsers, seems to be almost OK, but
In my 480 px breakpoint on Firefox on my mobile I get this : Image
My setup at this point is Image
But the dialog still comes up wider than the screen itself, is my setup for the dialog wrong?
What can I do about it?
I do not see any issues of my devices (PC, iPad, iPhone).
Maybe there is something wrong with your device?
alex4orly
Post by alex4orly »
The problem only shows up on Android when I introduce the 768 bp. WE have 4 different Android devices 2 mobiles and 2 tablets of different models.
It works fine on a neighbour's old iPad
If I avoid the 768 bp, then, on the Android and Apple tablets, the welcome screen comes too small - the setup of the 480 bp.
Does my dialog setup look OK to you? IT shows wider than the actual device screen and the visitor needs to scroll sideways to read the text inside the dialog. The content is a html page that at the 480 bp is set to 400 px with of the Layoutgrid and the iFranme it loads into is wider
Any suggestions?
The dialog setup looks correct.
Maybe the android devices have a different viewport size, so you will need to add an extra breakpoint?
alex4orly
Post by alex4orly »
Yes, I thought about , at what point?
I do not know which screensize your device has, so you will have to look this up yourself.
But I guess it's somewhere between 768 and 480
alex4orly
Post by alex4orly »
This is something I am confused about
When I check the resolution on my phone, it shows 1080 x 2220
So, what is actually, bp 480 or 768
alex4orly
Post by alex4orly »
Very good, but
1. How can I detect in JavaScript?
2. Is there a ratio between resolution and viewpoint? If so, what is it?
Thanks again
This depends on the device.
You can use the website to determine the viewport. Based on that you can an extra breakpoint,.
Or just try something between 480 and 768 and see if that works.
alex4orly
Post by alex4orly »
OK, On my mobile phone - the Viewport is 360 x 612
I added a bk at 320, set the dialog width at 320 but now, when the page loads, it loads as if I am holding the phone in Landscape mode.
When I turn the phone around and back - it repositions the dialog into portrait mode
I tried changing the dialog from JQuery to Bootstarp, it loads it immediatly in portrait view
With this issue of ViewPort, it seems it will be more practical to be able to load pages based on ViewPort sizes and not set any breakpoints at all, or am I wrong? Is that at all possible?
Thanks again
The viewport size is the breakpoint width.
Note that you can also set the size of the dialog to full width. Then you do not have to worry about the size for smaller screens.
alex4orly
Post by alex4orly »
OK, I don't see a setup parameter in the JQuery to set the size to 100%
Where?
If the breakpoint is specified in the RWD properties) and the browser's viewport gets smaller than the specified value, the dialog will switch to full width mode.
Note:
Set the 'position childeren' property to floating, otherwise the content of the dialog will not be flexible.
alex4orly
Post by alex4orly »
But the Dialog is initially hidden and only open on a button click
So?
This does not matter.
